The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
My phone was dropped it works but the screen is black!
I dropped my phone onto a tiled floor and now all i get is a black screen. It turns on and i can get calls and listen to music but the screen is black. HELP PLEASE !
Score 1
Add a comment
Chosen Solution
Unfortunately it sounds like the LCD itself is damaged, replacing the whole screen would solve this. :)
Score 3
2 Comments:
having same problem but why does it sometimes work fine if it's burnt out? It's very annoying. If I flash a flash light right into the screen I can see everything else is working fine
by
@dawhoda this could be a backlight issue instead of a screen issue, but you should rule out a faulty screen first.
If it’s a backlight issue, you would need someone who can microsolder to fix your backlight problem. :-)
by
Add a comment
This happened to me and my phone wasn't dropped. I could just see screen faintly so went into settings and turned up brightness and it's fine. Hope this helps.
1 Comment:
Yeah this you can't even see at all unless you shine a bright flash light directly into screen at like an inch away from screen. My conclusion is the display panel is bad like couple people said. Thanks guys.
by
Add a comment
Add your answer
alisha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 382
