Model A1199 / 2, 4, or 8 GB capacity
94 Questions View all
Why is my screen all white?
My screen is white, completely blank. Nothing unusual happened that could have cause it to blank out.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
i would first try to make a hard reset: press and hold the menu and the select button untinl the ipod restarts - this will take around 6-10 seconds.
if the screen is still blank after resetting the device - i would open the ipod and check the lcd connector, maybe you should reseat it.
but wait until the ipod is in sleep mode and use the hold switch to prevent the ipod from waking up
if the lcd connection is reseated, i would check the funtion again, use the hold switch and wake up the ipod - if there is still nothing on the screen - it could be a dead lcd or the logicboard died
Add a comment
Markus,
Thank you taking the time to answer...I have no idea how to open the ipod w/o breaking it or what a LCD connetor looks like, but I appreciate the advice and will check into it. If it works I will certainly post the results!
Comments:
you're welcome. on the right side of this page are links to the step-by-step guides.
the guide for the lcd is here
the tools you would need are also listed in the guide.
good luck
by
Add a comment
Add your answer
debichan2003 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 61
All Time: 11,745
