The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3318 Questions View all
Are the iPhone 5 glass compatible with iPhone 5s?
I have a working iphone 5s with a working LCD/Digitizer but a cracked/smashed glass. I also have a prestine condition iphone 5 glass with a bad LCD/Digitizer which I plan to use to replace the broken 5s glass. Will it work?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
No, they are not compatible.
Add a comment
I transferred the a working glass/digitizer assembly from my iphone iphone 5 onto my iphone 5S, everything worked like a normal the moment I put together the iphone 5S.
In short, the iphone 5 and iphone 5S glass/digitizer assembly are compatible with each other, and the glass itself had no electronic funtionalities at all, that means, the iphone 5 glass should work for iphone 5S.
Add a comment
5/5c/5s glass are all the same. It's the lcd/digitiser that is different.
I would find a way of sealing up the backlight else LOCA glue will seep into the layers.
Or buy a new backlight for a few quid, just needs a dab with soldering iron, then a bit of heat on the back to soften the adhesive. Else when lifting the backlight off it can break the top of the digitiser.
Good luck :)
Add a comment
Add your answer
iphonedoctorthefourth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 98
