The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
281 Questions View all
Is it possible to test the battery with a multimeter?
Is it possible to test the battery with a multimeter? HOw?
iPhones 1rts gen can show charging symptoms, but sometimes is difficult to identify if the problem is the System connector, CommBoard or battery.
Thank you
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Maybe, to get to the battery, use this guide. Then, you could test the 2 leads, that carry power. I believe that this is the red wire, and black wire. You might be able to do this without removing/unsoldering the battery.
Score 1
Add a comment
Add your answer
Flavio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,648
