Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
11898 Questions View all
Why is there a 750GB limitation with an optical drive bay HDD?
I would like to install a 1TB 2.5 HDD in the optical bay slot (Macbook Pro Unibody mid 2012).
I currently have a 500GB HDD in the optical bay and a 500GB SSD in the original hard drive bay.
I am curious to the 750 GB limitation that is noted in the description.
Product Code: IF107-080-3
Update
The specs:
2012 macbook pro
10.10.3 OS X
4 GB Ram
2.53Ghz Quad I7
500 SSD has 1 OS partition
500 HDD 5400 RPM has 1 data partition
1 TB HDD 7200RPM has multiple partitions
Initial config:
500 SSD in HDD bay
500 HDD (original drive) in Optical bay
Benchmark SSD:Write 1024KB (451.306 MB/sec) Max
Results:
500 SSD boots properly
500 HDD reads and writes properly
New Configuration 1:
500 SSD in Optical Bay
1TB HDD in HDD bay
Results:
the 1 TB drive worked fine.
The 500 SDD (with the primary OS partition) had difficulty booting. After several attempts, the SDD booted to the OS. I attempted to run a benchmark test. The results were sporadic and had several force restarts.
Benchmark SSD:Not stable enough to officially record
New Configuration 2:
500 SSD in HDD bay
1 TB HDD in Optical bay
Results:
The SSD worked fine.
After booting to OS (using SSD), the 1 TB drive requested that I Initialize the drive. (Disk utility shows the individual partitions (disk1s1 etc) without any names) Occasionally, a single partition will mount and it is not always the same partition that mounts from that drive.
If a 1TB drive works, maybe it needs to be <7200 Rpm?
Comments:
If you have a question about a particular product, please give a link to it so I don't have to spend ten minutes hunting it down. This forum is manned by volunteers, not by iFixit employees.
by
You could install your 500GB SSD in the optical bay and the 1TB HDD in the original HDD bay..
by
You could… but that would be counter-productive :( The optical bay bus runs slower than the other one on the machines. They were the same on later models.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
That is very curious. Other opt-bat devices do not seem to have this limitation: http://www.mcetech.com/optibay/
Score 2
Comments:
This "optibay" from mcetech seemed to make the difference. The benchmark difference was only 2 -10 mb/s instead of hundreds when installed with the ssd. I haven't tried the 1tb, but I'm confident it would work with this optibay. Thank you for the alternative option!
I'm not sure why, but the ifixit model does have a hardware limitation. Though, I'm not sure why that is, I will confirm that it does.
by
I think the issue is drive height. Back in the day 1TB drives were higher so they couldn't fit the limit of 9.5mm of the carrier. So, if you have a drive that is 9.5mm or smaller and doesn't pull too much power it will work. Remember the SATA interface does not have any limits from a drive size. The systems BIOS & OS likewise have no bearing as well. I still recommend using the newest the system can support.
by
Add a comment
Add your answer
kcme94399 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 350
