Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36 Questions View all
Why does my Book G3 14" Power Socket not turn on?
ok i had a problem with my ibook with the power socket and i tryed to sold it again but when i did it it does not turno on i just hear 3 bips and in te bottom of the touch pad i can see a Whie light well i can see it because the computer is without case but what is this? also i dont know how to sold it i just sold what i think it was. thank you
Score -1
1 Comment
You mean solder, right?
by
Add a comment
Chosen Solution
According to Apple, three beeps at startup mean "no good banks," which I believe means bad RAM. Or I've seen other folks on other websites suggest that maybe it could mean the RAM is just badly seated -- you might try removing and reinstalling your RAM chips? Here's the Apple page describing the beeps: http://support.apple.com/kb/HT1547
Score 1
Add a comment
If you are not a highly experienced person with a soldering iron I would not attempt this repair. On the other hand without repair the logic board needs to be replaced so if you are capable or know someone who is you can give it a try. Understand if the connector is messed up you will need to replace the logic board. Ralph
Score 1
Add a comment
Yeah thank you!! it did work but i still have problem to make it turn on by the blue and white cable how do i solod it i mean where in the hole i know where it was it but i dont no how and in what order should i sold yocan somebody help me!!.
Add a comment
You might advertise on CraigsList for someone who is good at soldering. For someone who knows what they are doing it's a very easy repair. I was able to salvage a very nice G4 iBook which had the exact issue as yours, and it's all due to the fact that I happened to run into the right person.
Add a comment
Add your answer
superbat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,310
