Designed to replace incandescent bulbs. More efficient, higher initial cost.
3 Questions View all
Question Closed
short lived CFl (6 months all over the house)
We have had several compact fluorescent bulbs burn out only after about 6 months of use at this time in every place we have used them in the house.
Add a comment
Most Helpful Answer
6 month is short - but possible.
  1. if the bulbs are cheap ones - they can die faster
  2. i would check (or ask someone) the real voltage in the house (maybe there is something wrong)
  3. how often do you use the bulbs on a regular day ?
the "starter" inside the bulb dies first - the more often you switch dem on, the faster they die - i had once a cfl bulb that was always on, i only switched it off 6 times in 7 years - another one was switched with a motion sensor - this one died after a few month
Score 2
Add a comment
CFL life is (or should be) measured in startup events, rather than by time. If you are constantly turning it on and off, it will have a much shorter lifespan.
Once a CFL has started, it takes very little power to keep it going. As a general rule, if you leave a room lit by a CFL and expect to return in one hour or less, leave the light on.
As Markus suggested, check the voltage level. Some utilities provide higher voltage than is really required, and that may cause appliances to fail prematurely. In the U.S., your power should be at 110 volts to 125 volts. I believe this is correct for Canada also.
Score 2
Add a comment
cfl bulbs used upside down, such as in a ceiling fixture, significantly reduce their life because of the heat which rises up and causes overheating of the components in the electronic circuit enclosed in the base. I've gone back to incandescent bulbs for that type of use.
Add a comment
Is your light fitting in a recessed ceiling fixture? I have found that too high a wattage causes overheating and an early death. This is more noticeable in the cheaper brands.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,914
