Display backlight turns off after a couple minutes
My MBP is working greatly. However, after a couple minutes using it, the display backlight turns off. I've connected the MBP to a TV, its working. I even put a light behind the display and I can see that it is working properly, it is just the display backlight that turns off by itself after a couple minutes. What can I do? Thanks.
1 Comment
This model does not use an inverter. Inverters are used on CCFL backlights. The LCD on your computer is a LED backlight. It has an LED driver circuit on the logic board. I'd be more concerned with the LED driver than with the LCD. The whole issue sounds like a backlight issue not an LCD issue
by oldturkey03
