Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
89 Questions View all
Is it possible to replace the HDD to Sandisk SDSSDHII-480G-G25?
Would an iMac with a SSD (Sandisk SDSSDHII-480G-G25) hard drive instead of the standard HDD
Add a comment
1 Answer
Chosen Solution
Here's the IFIXIT guide to remove your current HD: iMac Intel 21.5" EMC 2638 Hard Drive Replacement. Keep in mind this is a difficult system to open and its very easy to damage ones display panel it you don't use the correct tools and take ones time.
As to replacing your current HD drive with a SSD drive: Yes, it can be done you'll need to prep the drive up externally before you install it. You may want to talk with SanDisk support to ask them if they have tested their SSD in any of the newer 21.5" 'Thin Series' iMac's.
Score 2
Add a comment
Add your answer
serzhik90 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 215
