The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
357 Questions View all
Washer won't fill with water.
My Kenmore 110 washer has trouble filling up with water. Whenever we set it to fill (hot and cold, doesn't matter) it sputters a bit and only pours in a little stream instead of the strong flow. What's happening?
Score 1
Add a comment
1 Answer
Chosen Solution
Water Inlet Valve
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
Low Water Pressure from House Supply
Other Causes and Conditions
How it Works:
If the washer fills very slowly, the water pressure from the house might be too low. If the water inlet valve isn't leaking and there are no other symptoms this problem does not need to be corrected.
Score 3
Comments:
Might be a screen at water valve or water hose connection that is partially clogged up allowing only small stream of water to come in. Could also be a defective valve that is not opening all the way.
by
Add a comment
Add your answer
Jonathan Rico will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,608
