Soldering ram slot on the logic board
While performing a repair I may have bent the logic board enough to cause the RAM slot closer to the keyboard to become loosened. Now any RAM stick I use in this slow will cause the computer to hang and reboot. The other RAM slot works fine.
I was planning on using a thin soldering iron to reconnect any broken circuits connecting the RAM in place. I see thin copper wires from the logic board to the RAM slot that I may need to investigate. You can see them below the barcode sticker in this image.
Has anyone performed a similar repair before?
2 Comments
Can you give us the last four digits of your serial number so we can correctly identify your system.
by Dan
My serial is W80262S6AGZ. It's a mid-2010 model so I believe it allows 4GB per slot?
by Aram Kocharyan
