Why won't my kenmore 800 washer fill with water
why won't the washer fill with water. checked the water valve with meter both coil are not open.
Check the water inlet valve
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
Replaced water valve still not filling
Open the water inlet valve.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 565
