Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1402 Questions View all
Can I swap iMac & MacBook harddrives?
Here's the thing: I've owned a A1224 20" Aluminum iMac for 2 years but recently purchased (used) a A1181 Macbook 13"...I'd basically like to swap the harddrives, is this possible?
iMac: 320gb (7200)
Macbook: 160gb (5400)
Will either machine accept the other's harddrive? Will the faster speed affect performance of the Macbook (i.e. will their be issues with overheating, change in power usage, etc.)?
I haven't opened either machine, so I suppose this is all assuming the sizes match up.
Thanks for the replies....I've gotten a new harddrive and have done the migration successfully.
Score 1
Add a comment
Most Helpful Answer
the imac uses a 3.5" hdd and the macbook a 2.5" hdd - you can't put the 3.5 into the macbook, but the 2.5 would work in the imac
Score 2
There are really no problems with heat anymore till you get to the 10,000 RPM 2.5 drives. iFixit has a nice assortment of both size SATA drives that would work for you, take a look:
Add a comment
While you can't put the physical hard disk from your desktop into your laptop, you probably just want the data off it.
Get a new hard disk for your macbook (500 Gig 7,200 is about $100 US). Install.
Boot the macbook into target mode (turn on while holding down the T button)
Connect to your iMac via firewire.
On your iMac, go to Applications / Utilities and run Migration assistant.
Good to go!
Add a comment
Add your answer
ctrimmer6 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,819
