Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
855 Questions View all
Touchpad clicks but doesn't move
The touchpad on my Macbook Pro 13" mid-2009 stopped working. I replaced the touchpad with another one and the click began to work, however I cannot move the cursor. Is there anything I can do try to do in order to fix this, or can I conclude it is a logic board problem? Let me know, thanks!
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Your battery maybe bulging out in the middle which was why your click plate was not working to start with. I would pull the battery and carefully check it.
At this point you either didn't seat the ribbon cable into the connector on the logic board correctly or you damaged the ribbon cable. Take a good tight picture of the ribbon connector on the logic board as well as the ribbon so we can see things and post it here.
Score 1
Add a comment
Add your answer
Coby Ilas will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,112
