Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
Why wont the LCD cable stay in?
Hi, I am replacing the screen and home button on my iPhone 4. The LCD cable is long enough to go in its socket, and looks like it should fit, but it does not pop in, and keeps sticking straight upwards. Any thoughts ?
Add a comment
Chosen Solution
Remove the rubber bumper from the top of logic board, it may not be installed correctly. Fold the flex cable properly, many have the dotted lines where it should be folded.
Comments:
It turned out that the cables weren't folded properly. In the end I also had to use more force that I thought to get the cable to go in, but now all is well and iPhone is fixed.
by
Add a comment
Also make sure that both cables are pulled through all the way and aren't pinched between the lcd and chassis.
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 34
