Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36452 Questions View all
Soldering U2 (what tools needed?)
Hello everyone,
I would like to start micro soldering, i have phone compagny but sometime we broke some chip during repair.
What is all tool needed for remove U2 chip and replace with new one ( i already have the new U2)
Can someone explain me how to desoldering and how to soldering back, which method is the best ?
Thanks
Add a comment
Chosen Solution
Hey,
You'll need to start off by getting a good soldering iron, something along the lines of a Hakko, then you will need decent flux, and decent solder at different widths, for smaller stuff go with the thinner soldering wire, try and make sure it's multicore solder as that also contains flux in the solder and helps a lot. A good reflow station will be needed for sure. You will definitely need a decent microscope to, you can't do it by eye, as the chips are so tiny! If you do plan on soldering a lot, you'll more than likely need a fume extractor, as the fumes from soldering are bad for health.
Hope this has helped. :)
Score 3
Add a comment
Tools only:
Hotairstation/Reworkstation
Soldering Iron
Solder
Flux
fine quality tweezers (also important)
Changing the u2 chip is one of the easier IC's to change but still not the place to learn micro soldering.
Practise and get to know your tools on dead boards until you know how to remove parts without destroying the whole board.
Score 1
Add a comment
PPD120E or good soldering iron
Add a comment
Add your answer
Phonetech93 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,064
