Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
Can't call out or receive call after drop in water
Dear iFixit community, I have an iPhone 5 white 64 GB. Sadly, it had an accidentally bath in a lake. Not salt water. So it has dried up. It power up and down fine, WiFi works and so on. But for some reason, I can't call out or receive calls. I have done the following: 1. backup the device via iTunes 2. checked for updates and updated with the latest 8.3 iOS and the update about cell network provider (I think is the translation) 3. changed the SIM-card. 4. Factory reset. After that, I managed to do one call out and one incoming call. But then it died again. After these one-timer, the ability of making a call and receive a call stop working. All other function are working fine, like web-surfing, take mail via WiFi, get updates via WiFi.
So given that, any thoughts of what can be done? Can I maybe replace the SIM-card reader?
Kind regards
Leopold, Sweden
Add a comment
1 Answer
This may not be a solution but from my understanding there is a resistor on the main board called Board_id, which is responsible for how the devices identifies itself (eg. Apple TV, Apple iPod, Apple iPhone Cellular, Apple iPad Wifi Only, etc) it may be that the water damage has effected this chip/resistor causing it to malfunction in a way.. not sure but would certainly assume it's board related.
Sorry I can't be more conclusive, feel free to correct me if I'm wrong on the above! it's a bit of a broken memory!
Will
1 Comment:
Hello Will! Thank you for your feedback. I have popped it open to check what can be done. As I suspected, every water-damage-indicator has been activated. See attached image. I have put the rear case in a silica bag while eating lunch. Will update on progress after that.
[image|576890]
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,650
