Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
How can I determine why my MacBook will not boot?
Based on my intermediate knowledge, I believe it is either the logic board or the topcase that is malfunctioning. Would anyone be able to help me determine how to pinpoint the problem piece of hardware?
EDIT: Sorry, I forgot to mention that there is no response at all when I try to power up. No chime, the screen doesn't turn on, nor does the white LED. Also, I've tried resetting the SMC.
Thanks in advance,
Nathan
Comments:
Please describe the malfunction.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Try to power & boot the machine without the top case attached. If it power on then you'll know the top case is the culprit. Check one of my answers here:
How does the keyboard communicate with the logic bd?
Score 2
Comments:
Thanks so much. Booted up right away. Guess I'm in for a new topcase. Don't really mind, much cheaper than a logic board.
Thanks again,
Nathan
by
I am at a loss to know why you recommended that procedure. I would never have done that. Would you tell why? + vote for being right
by
Just wondering, mayer, did you know about this "jump start"? I've never heard of it at all before, and find it fascinating. It can definitely help rule out or determine a faulty top case. I guess there's a possibility of frying the whole logic board, but I was willing to take that risk. Also, to clarify, I shorted the board where the top case connects to the board itself. I was not able to see a power logo, and although it was very risky, I just started making somewhat random connections, in an attempt to boot the computer.
by
To mayer: why I recommend this procedure ? Because if you don't have a known working top case as spare part to troubleshoot the macbook it's the usual way a tech will determine if the top case is in trouble or not. Why do you think these two power solder pads are available and identified on the logic board ? Why not recommend this procedure ? The OP already said he tried SMC without result and has no power reaching the logic board so IMHO I think it's the adequate procedure for his specific issue. Now if the OP thinks the procedure is too hazardous he can ask a tech to do it for him but others users here can use the procedure and save the price of a logic board replacement.
by
In my case, it wasn't really identified. I couldn't find them.
by
Add a comment
What do u see on the screen? Does any sound at all come from the laptop??
Comments:
Nothing at all.
by
Add a comment
Remove the battery and power cable and press the start button for 5 seconds. Now with the battery out reconnect the AC power adapter and try starting up. If this works, plug the battery back in and let it charge for an hour and then see if it works. Let us know the results and we'll go from there.
Comments:
Resetting the SMC did not work.
by
Did you try the rest?
by
Add a comment
Add your answer
Nathan H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 822
