Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Left side of screen not working - Cannot press 'Q' '1'
After replacing the screen on my iPhone 5s (16GB white and silver) the left side has some daed spots, I cannot press 'Q' or '1' in portrait, the bottom left icon also doesn't work.
What should I trouble shoot? There are no strange lines or screen bleeds.
Score 1
1 Comment
Thanks guys, indeed the iPhone was bent, I did bend it back and didn't think it fit with pressure. I'll check with the screen not inserted, to see if it's caused by the frame.
by
Add a comment
Most Helpful Answer
I would open it back up again and reconnect the digitizer cable, maybe there is some dirt in the connector? Give it a wipe with isopropyl if you have any. If that doesn't work, it might suggest that the new screen is faulty. Also check the phone is not bent, did you have a hard time getting the screen to clip back into the frame? I once did a screen repair on a 5S, that had similar problems you describe, on close inspection, I noticed the iPhone was bent, and so the new screen was obviously bending to the shape of the frame.
Score 1
Add a comment
Make sure you screen is not being pressured by anything. Try loosing the LCD Shield plate scews and check the phones reaction. As Michael stated, if the iPhone is bent, the new screen will follow the shape of the frame and it would damage the new screen. If there's no line on your screen and everything is shining bright, the cables are probably not the cause of your issue.
Regards,
Bruno
Score 1
2 Comments:
Bought the gTool and got the corners perfect. Screen fitting good.
That did not solve it, when I remove the metal backplate it seems the screen responds better, the plate doesn't look bent. Whattodo whattodo
by
Ey Giovanni. Three years later I’m facing the same problem in my 5s. What did you do to solve it? Thanks!
by
Add a comment
Add your answer
Giovanni Joubert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 13,904
