Erratic horizontal lines on LCD display
I have a Macbook 13" Early 2008 Dual Core 2 Duo Penryn Model A1181.
Erratic horizontal (white) lines appear at random positions on the LCD display.
A simple pressure on the screen bezel or even a gentle play with the inclination of the screen causes randomly :
- more lines
- or return to a clean display (with no lines).
See attached pics with more and less lines
(please ignore the glare in middle of screen caused by the camera flash)
note :
- No lines appear using an external display (mini-dvi port) works fine.
- The screen brightness appears fine in any position
Any suggestions on how to investigate this problem and diagnose the cause of the problem ?
3 Comments
What happens when you use an external display? Is the image on it clean.
by Dan
Yes, an external monitor shows a clean image. I guess this means the video card itself is fine.
by Dan Mac
Much thanks for your answer !
by Dan Mac
