Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1189 Questions View all
Can we add a HDD in Acer Aspire R13?
can we add any hdd in acer aspire r13?
Score 1
2 Comments
How is it with RAM?
Can we upgrade it from 8 to 16 GB?
Does somebody know a teardown howto?
by
You can only change storage, everything else is soldered on the motherboard or other little boards in the case. For the teardown it seems really simple, juste take a look on the link :).
http://laptopmedia.com/news/inside-acer-...
by
Add a comment
1 Answer
Most Helpful Answer
You can not, because there is no 2.5" slot. It's a M.2, mSata or equivalent (I'm not sure of which) so you can only add a different SSD with the same connector. There could be two slots and only one SSD but I'm not sure either. For further information about which type of SSD you could use and if there is a second slot available you better should contact Acer technical support (also to know guarantee condition about SSD adding/changing).
edit : I'va checked and there are two slot in the R13 but I can not find which type they are.
edit2 : and finally i found it, it's a m.2 slot :
review here
Score 2
Add a comment
Add your answer
Aman Bakshi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,302
