Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4035 Questions View all
Why has the iPhone 6 stopped working after a successful water repair?
Hello,
Recently I encountered a water damaged iPhone 6. It showed no signs of life (even though the battery still had a healthy charge discovering later when running tests)
I stripped the phone down, soaked the main board in 99% alcohol for 5-6 hours, dried the board and then brushed it clean from any water damage. After replacing the dock connector flex cable, the iPhone powered up and all functions worked as they should.
About a day later now, it is dead as before, showing no signs of life. The battery had been charged up to about 78% the evening before and the phone was working as it should. I have now replaced the battery and still nothing.
Any thoughts?
I did not remove the IC chip metal covers as they appear to be welded to the main board.
Thank you.
Comments:
Remove all the EMI shields clean it again and replace the battery. That is a must, not an option
by
The process you followed is incomplete and dangerous. It's like saying you had a toothache and took one Aspirin. 1 day later, the toothache is back again. Sure, the iPhone board underneath the shields is still decaying and the electricity running through it is making any short worse by the second. Unplug that battery ASAP then do as jessa and old turkey are saying.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
"I did not remove the IC chip metal covers as they appear to be welded to the main board."
^^which means that 80% of the board was never cleaned, and subjected to electricity. This is the problem. You have to desolder the shields, then clean, and then find the shorted component and replace it.
jessa
Score 3
Comments:
Here's a video that shows you why cleaning the board without removing the shields is insufficient. https://www.youtube.com/watch?v=DubLr9pt...
by
Add a comment
Add your answer
zentech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 599
