Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Backlight works, but there is no display.
Hello,
I have an iPhone that will not display an image, but the backlight turns on. After inspecting the area around the lcd connector I determined that the L44 display filter was missing. I replaced it with one from an old iPhone 5, but nothing has changed. The phone is still turning on but not displaying an image. When it is plugged into a charger it just beeps periodically. I have tried many different LCD's so I know that is not the problem. I will include a picture of L44 that I replaced.
. This was my first time replacing something this small, so I don't know how good of a job I did. Does anyone have any suggestions for me?
Thanks
Add a comment
1 Answer
Most Helpful Answer
After replacing a Filter you should always check if you have done a proper job with a simple multimeter. In this case connect the probes of your MM according to the picture I added. It should beep when you connect them. If they don't that means you do not have continuity and the filter mostlikely is bad or not soldered properly. 1 Filter = 2 measurements (each color represents 1 measurement)
While you at it: check the other filters too.
Why was the filter missing ? Waterdamaged board ? ripped of ? maybe there are more components missing the the lcd connector ?
Score 1
1 Comment:
hey i suffer the same problem backlight coming and no image.. and i checked my diodes they give error so i removed them and attached the jumper.. but still no image on display... i also tried new lcd but nthng is there
by
Add a comment
Add your answer
mSuj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,564
