Pls HELP! Anybody know what this code is? 4SNS/1/40000000: lbor-9.426
I run extended AHT on my MBP 2011 13" and this came up on the results.
Please I need to know what wrong with my MBP.
It runs very slow and stuttering.
Thank you in advance.
4 Comments
denzdaniel, that looks like a Battery Current Sense error. Have you tried a SMC reset?
by oldturkey03
yes i did, 5 times! I even did the NVRAM reset. Still slow macbook pro.
How positive you are that the battery sensor is the problem?
thanks.
by denzdaniel
Hi Mayer,
DV13 are the last serial figures.
Running Mavericks 10.9
No anti-virus installed, no MacKeeper.
The problem is caused by the coffee spill.
I did the rice thing for a week, cleaned the Logic Board with isopropyl.
I cleaned all surface carefully and all port. I used the blow dryer to dry it.
It works, but it is just super duper slow. Yeah i get beachballs, but the system is just slow. Everything is slow.
Boot up takes forever, after login everything just is just very slow.
So i did the AHT then I got those numbers/codes.
I will try to boot to an external drive thanks. I will update you.
by denzdaniel
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*
by mayer
