Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
42 Questions View all
What would be the max. HD capacity when replacing internal drive?
I want to upgrade the internal hard drive. It appears to be a 30 gb . How large can I go as far as storage and the ibook still recognize it? Also what type of drive should I be looking for. Example " ATA 2.5 inch"..
Add a comment
1 Answer
Chosen Solution
Without jumping through hoops to get it formated, you should stay under 128GB. An ATA or IDE drive will work fine. Just stay away from the SATA drives. This drive will work just fine for you: 80 GB 9.5mm ATA Hard Drive
Here's a bunch of new IDE drives up to 320GB that will work for you:|0&N=6885
Score 2
Add a comment
Add your answer
James Brizendine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 625
