The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
dropped 3ds and need help its perfectly fine but wont turn on.
Hey I accidentally dropped my 3ds while playing a different game and now it wont turn on I press the power button and then the light turns on for a couple seconds then it turns off can somebody please tell what happened to it and how do I fix it please
Score 2
1 Comment:
@someguy12974 maybe loose, otherwise then that idk tbh
by
Add a comment
Have you tried opening it up? It's pretty likely that a part inside has been disconnected or broken. Check out iFixit's teardown for a good idea of what the inside should look like.
If everything else looks good, another possibility is that the battery has been screwed up and needs replaced.
1 Comment:
I had a simar problem except I didn't drop mine. My new 3ds will not turn on at all, just play button sounds and system audio for a short time. Good luck man, new 3ds is extremely flawed, it's only a matter of time before everyone finds out.
by
Add a comment
I know what happend the ribbon cable got disconnected
2 Comments:
@sqwerky, can you elaborate on your answer? You say "the" rather than "a" ribbon cable got disconnected, implying you have a specific one in mind. Which one are you thinking it is? There are, after all, several ribbon cables inside.
by
sorry for the extremely late response
by
Add a comment
Add your answer
some guy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,790
