Model A1288 / 8, 16, or 32 GB capacity
583 Questions View all
Screen cracked, and now black spots appearing
The device has a thin crack, no problems with how it works. After it was left in hot car, a black dot appeared on screen, and now it is growing in size, obscuring an app icon.
Score 47
Comments:
thanks for your help...sounds like it may be more prudent to get a new one!
by
Add a comment
Chosen Solution
sounds like the lcd has a crack, the term "screen" is problematic, some say screen to the front panel assembly (aka the touch screen) and others call the lcd a screen.
but since the "touch screen" can't get a real black dot - it must be a crack in the lcd.
you have to replace LCD and if there is also a crack on the front panel - you must replace it too.
Score 8
Comments:
i left mine in my pocket and pulled it out and it became like this
by
Add a comment
its either oil from your hands getting onto the lcd screen or pressure points on it, I'm not sure which most people seem to think it's pressure points base on my solutions that have worked I think it's oil. First thing to do is cover it with something to stop it from growing(packaging tape worked at least as well as a screen protector on my droid x). After that, it will very slowly decrease in size by itself. If you get it cold it will speed the process along.
Score 3
Add a comment
I have the same thing on my IPhone5c it have black spots on it and it want let me do nothing i tried to do everything and I went to put some water on it still did work so maybe try clicking home button 3 times or Try clicking the Home button 3 times (really fast). If that doesn't fix it, go to Settings/General/Accessibility/Triple-click Home, and select the "White on Black" option. Then, triple-click the Home button.
Add a comment
I've crack my phone like 3 times and now there a line of black things just growing into it, how do I fix that, also my phone is a j3 Luna samsung
Add a comment
My phone has a crack and now a big black spot is on my phone how do I get rid of it or do I have to take it in for someone to repair it my phone is a LG k7
Add a comment
Add your answer
lorettalevy will be eternally grateful.
Past 24 Hours: 36
Past 7 Days: 174
Past 30 Days: 919
All Time: 88,429
