The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 Questions View all
Question Closed
My Acer C720 will not turn on at all
I really liked my Acer C720 but one day it just would not turn on. When I press the power button, nothing happens. It should turn on anyway when I open it, but that doesn't happen either. The unit seems to charge according to the LEDs. But no go.
Any ideas?
2 Comments
I ordered a new motherboard and although it was a little dicey here and there I successfully installed it using your guide. I am very grateful to you for having posted it. Thank you so much!
by
Add a comment
Chosen Solution
Are you 100% sure it is not powering on and not the screen itself that is not powering on? Try hooking it up to another monitor or TV to see of it works. If this fixes it you need to replace the monitor. If not you are looking at a bad DC jack or video card most likely or ram. Either way these are all soldered onto the motherboard. It will need to be replaced. You can follow my guide for that.
Add a comment
Thanks for your answer. The LED's don't light up at all so I presume it is not the monitor. Where can I find the guide for replacing the motherboard?
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,050
