Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
515 Questions View all
Trying to use and external microphone.
The internal Mic in my Macbook is broken. When I install an external Mic, it is recognized in the sound panel, but the system doesn't receive any input from the mic and I've tried several.
Add a comment
1 Answer
Chosen Solution
I would make sure that under System Pref, Sound, Input and Line In are selected which is obvious you checked that. How are you attaching the microphone? Is it a USB mike, through a mixer via the XLR ports, does the mike require a 9 volt battery if you don't have a USB or FireWire interface with phantom power? Are you attaching the mike through the audio port via a 1/8 inch jack cable?
Post your specs and maybe someone here can figure out a solution to get the MacBook to recognise the mike.
steve
Comments:
It's just a standard non power mic attached to the 1/8 audio in jack. I have three USB ports and with firwire and the headphone in/mic in ports.
People have suggested using a USB mic instead.
Thanks.
by
Add a comment
Add your answer
kroddz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,241
