The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3508 Questions View all
iPhone 5S shows low battery black screen even when it's not connected.
I am repairing friends phone. Since I don't know the history of it and it was bought second hand I can't say if it was water damaged or not. Phone itself was roughly beaten and display changed. It was working ok and charging awhile then one moment stopped receiving charge.
After I have transplanted the motherboard and home button to another housing (being almost mint but with dead motherboard) I was able to charge the phone — after sitting on low battery screen for half an hour it booted.
Then it again stopped taking charge in few days. After some troubleshooting we discovered that applying pressure to lower right corner of the screen start the charging and decided it was due too loose connector.
I didn't repaired it instantly and in a while friend reported that method of applying pressure no longer works.
Now phone is in the state that it is showing Low Battery Charging black screen even when it is not connected at all. This one
And lighting connector icon is flickering slightly about every second.
I can't say if it is really charging or not. It sure is not booting. Hard reset doesn't help. I can't put it in DFU.It is not showing in System Profile USB section. Disconnecting battery doesn't help.
I have multimeter if that is needed. Anyone has any ideas how to troubleshoot it further?
P.S. My girlfriend is now using iPhone 3GS I was able to jumpstart after it was seemingly dead after fake charger. I wonder if this problem is of the same kind.
Score 1
Add a comment
Chosen Solution
Gonna go ahead and guess U2 IC, at this point
Score 2
Comments:
Might be yes. Could I please ask you to come and answer to my other question if you remember about 3GS circuitry?
It is here How to check how good battery is with only phone and multimeter?
by
Add a comment
May be the problem is the lightning connector, shorted somewhere or oxided yet. Look inside it, try to clean with trieline, or also you cant try to brush slowly it. Let me know
Comments:
That is for sure not the case. I have tried disconnecting dock connector from logic board and it still show charging screen.
by
Add a comment
It was one of the chips as tech in local soldering shop told me. It was pretty straightforward and pretty inexpensive repair by specialist.)
Add a comment
Add your answer
iskra will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 43
All Time: 1,903
