Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
Question Closed
Is the logic board of MacBook Air 13" Late 2010 work 2011
Hello,
My logic board of MacBook air 13" Mid 2011 is broken, and on ebay I've found the price starting 250€ to 350€. But I've seen also that the number of the logic board 1369 is the same as the MacBook air 13" Late 2010 and price starting 150€.
I don't mind the processor or RAM or anything, I just want to know if, as far as the number is the same, will the macbook air 13" late 2010 logic board work on a macbook air 13" mid 2011 ?
So I can fix my laptop for cheaper.
Thanks in advance !
Add a comment
Most Helpful Answer
Yes, it will work. However, you will have an issue w/ the right-side speaker assembly. I'll try to explain. The speaker assemblies for both are L-shaped, but they have a "bump" at the top (logic board end) which the logic board has a matching cut-out for. The 2010 is a rounded bump/cut-out, while the 2011 is squared off (see attached image, 2011 board installed, 2010 board laying on battery).
Okay, so use the 2010 speaker assembly, you say. Just one problem, the top cases have stiffening/support gussets that run underneath the speaker assemblies. And, of course, the 2010 and 2011 have them in different places, meaning the clearanced areas in the top-case side of the speaker assembly on the 2010 hits the gusset on the 2011, which then blocks the bottom case plate from sitting flush. You could probably grind your own clearance in the speaker assembly, but they are tuned using the shape of the assembly, so your sound quality might suffer a bit.
Bottom line, I think you could probably make it work by "massaging" the speaker assembly, if you want to. Keep in mind you'll lose Thunderbolt by going back to 2010, as well as keyboard backlighting. Also, you'll likely need the 2010 keyboard/trackpad cable, as the connector is in a different spot on the 2011. The 2011 cable is more than long enough, but I think you'll be stressing it by trying to bend it and change the 90-degree folds to realign it.
Good luck!
Fred
Score 1
Add a comment
Noone ??
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 524
