Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
What are the dimensions and weight of the iPhone 4 battery?
I'm curious about what portion of the iPhone 4 volume and weight is attributed to its battery. Could you post the dimensions and weight of the battery?
Add a comment
Chosen Solution
There's a clear picture of the battery dimensions as in relation to the iPhone's.
The battery is-
Li-ion Polymer Battery
3.7V 5.25 Whr
APN: 616-0513
The iPhone is-
4.5 inches (115.2 mm)
2.31 inches (58.6 mm)
0.37 inch (9.3 mm)
4.8 ounces (137 grams)
here's the certificate
Annnnddd some clear shots of the battery. Hope it helps! It's all I can do short of getting my hands on one and busting out a postage scale and tape measure.
Score 1
Add a comment
if you check for the battery in any re-seller web you will find full specs.
4S battery weight 26g
Add a comment
Add your answer
Mark Jarvin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 90
All Time: 13,388
