Washer overfills only on the rinse cycle
11020942991 Kenmore washer top load overfills only on the rinse cycle. Does the timer control the water for the rinse cycle . The water level is good on the wash cycle
Pressure Switch
If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,174
