Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
1/3 left side of touch screen not working even with replaced digitizer
Hi all,
I recently found the 1/3 side of my iPhone 3G touch screen not working. The 2/3's on the right side still work perfectly. It's like a perfect line vertically down separating the working side with the non-working side.
As a result, I have restored the device and replaced the digitizer thinking that was the most obvious problem. Still no luck, the exact same area of the touch screen doesn't work.
Any help is appreciated.
Thanks!
Score 1
Add a comment
Free Shipping on all orders $79.00 and up.
Browse Our Store
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
The digitizer uses a grid of capacitative sensors, with each row and column getting its own wire on the flex connector -- so any problem with the sensor or connection can cause an entire set of rows and/or columns to die.
If you already tried replacing the digitizer, take it apart again, and look at the connector for the touch screen on the main board with a magnifying glass -- if you can find some dust to clean off of it, that might fix it (as might the act of taking it apart and reassembling it). Otherwise, by process of elimination, it's either a damaged connector or a broken drive circuit -- either way, you'd have to replace the main board to fix it.
Score 1
Add a comment
Add your answer
jaymurray will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 58
All Time: 15,521
