The current line of iPod Touch comprises six (6) different generations.
3345 Questions View all
iPod tells me to plug into iTunes but it's locked.
my ipod tells me to plug into itunes but when I do, a box pops up and tells me I can't connect to itunes because it is locked by a passcode. I can't enter my passcode until I connect to itunes.
Score 1
Add a comment
Chosen Solution
Disconnect the iPod from the computer and unlock it before you plug it back in. It should let you unlock it whether it's plugged into the computer or not, but try that anyway. If that does not work try a hard reset of the phone by holding the sleep and wake button till the phone shuts off and boots back up and reconnect.
Score 5
Comments:
+ agreed
by
ALso, if you have the "automatically sync when connected option checked on iTunes I would disable it and see if you can unlock it then>
by
+ Ralph
by
Add a comment
hold the on off button and the circular button and then slide and plug into itunes
Score 1
Add a comment
i have the same problem, you can not type your code in and then plug it in because it wont let you do any thing unless you plug it into itunes, (it shows the plug pointing to itunes).
Add a comment
Add your answer
Madeline will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,822
