How can the drum be repaired?
The drum of the washer is loose and is rubbing against the front of the washer and allowing water to be released during washing. How can this be repaired.
Update
11042822201
11042822201
Rear Drum with Bearing - Part # 1515039 Mfg Part # W10253864
RepairClinic Item # 1515039
http://www.repairclinic.com/RepairHelp/H...
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Thanks for the information and your time
Is there any way I can get a diagram of the washer on how to disassemble and assemble it back also I need to know the part numbers for both the bearing and the drum and where I can possibly purchase the items.
Never mind the previous request I found what I need in your earlier reply. Thanks a lot
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 292
2 Comments
Please give us your model number.
by mayer
Model number is 11042822201
by Von
