Why didn't the YLOD method work for the PS3?
I did everything that was I told but it didn't work I applied thermal paste heated the motherboard but it didn't work. Did I have to make the mother board really hot?
Chris Sanchez, here is my answer to a similar question. First you do need to remember that this will only work if your YLOD is caused by solder fractures (actually it is more related to the bumbs on the substrate of the chip, but lets not worry about this now;-) and if they are not to extreme. Reflowing any board with a heatgun is not an exact science and as such does have a certain amount of failure. The proper fix for this would most likely be a professional reball. Anyhow, the biggest reason for failure to reflow is not enough consistent heat. There is a fine line between reflowing and absolutely melting the solder, so one needs to be aggressive without going over board. If nothing else, get a couple of temperature probes and see what heat you generate. You also need to make sure that you apply the thermal paste properly etc. Follow the guide from here and keep on trying. If at first you don't succeed....:). Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 111
