My Laptop can't connect to any wifi
it can see the signals and when i try to connect , it comes with an error meesage "can not connect to this network"
pls what can i do
pls what can i do
Depending on which model you have, it could be that your network is WPA-2 security or similar. In some older models, only the wep security level is supported. If this is the case, all we have to do is lower the routers security level down to what the laptop can handle. Did you set up the network/router? If so, do you remember what security level you set it to, if any? What is the model of your laptop?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 85
Have you tried rebooting the machine?
by Tim
What model is your laptop? What model is your router?
by Robert
