The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
306 Questions View all
XBox 360 S does not (start/complete) boot sequence.
Got the console from someone who claimed the unit would work and then freeze up after a few minutes.
He needed the original power supply for his replacement console, so I bought one to use for myself. One plug tested at 5V. The other tested at 12V. I don't remember measuring current. The console AC adapter was plugged into a surge protector sharing a TV, an HDTV antenna receiver, and a laptop AC adapter.
I used an HDMI cable which was working on an original XBox 360 console and then an OEM component cable.
I can open and close the disc tray with an audible beep.
Hitting the power button gets me a green light and I'm forgetting whether there was a beep.
Using an original XBox 360 wireless controller, when I pressed the XBox Guide button to power it up, all four quadrants on that button started blinking. I replicated the same results using an original XBox 360 wired controller over several USB ports, but not all of them.
I believe the fan was spinning in all instances.
The TV still has yet to receive a signal (whether on HDMI or component).
I also noticed ... an X-clamp! ... in the teardown guide. After fixing several original XBox 360 consoles, I really want to get rid of the 360S' X-clamp and replace it (and perhaps the thermal grease).
What else should I try and examine in order to repair this console?
Thanks for reading!
Add a comment
I think it's totaled
Add a comment
did you try replacing the RAM drive or the motherboard?
1 Comment:
I agree replacing the motherboard will "fix" the problem. I am still interesting in working with the original motherboard. As for drives and RAM, I am only familiar with the HDD and the motherboard's internal RAM.
by
Add a comment
that may fix the freezing
Add a comment
and for the connectivity try replacing the HDMI output that is on the back of the X-box 360 S
Add a comment
I hope this will be helpful
Add a comment
sorry that all of my answers were all separate
Add a comment
im actually not entirely shore if it uses RAM sticks/drives or if it's built into the motherboard of the xbox
Add a comment
this type of problem is also more commonly know to happen to PCs as well. and generally how you fix it is by re-installing the OS of the PC, so if you can figure out a way to get a copy the OS of the xbox and then re-install the OS you may be abal to fix the problem. I had a similar problem with my laptop and a friend of mine fixed it by re-installing the OS, so I think it my be possible to do it with your xbox
Add a comment
Make shore not both the componant and hdmi are plugged in
Add a comment
Add your answer
lkvee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 3,790
