Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
393 Questions View all
MacBook Pro seems dead, after trying to put in USB cable in
Hi!
My MacBook Pro was on the table with only the power adapter, the TV and a mouse connected to it.
I wanted to plug in my iPhone into the USB port. As the USB cable touched the MacBook Pro everything went dead like at a short circuit or when there is no power at the house.
I was thinking after that I might have mixed up the cables, and the one I was trying to use was the one I keep in the car, what is not an original apple product.
Now, not even the power adapters green/orange LED shows when I attach it to the system, is it totally dead?
I tried every 10 sec start and so on, but it does absolutely nothing. Any advice?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Do you live in a dry and/or cold climate where you have a lot of static electricity?
From what you describe here it sounds like you zapped your system via the USB cord. The USB ports do have a fuse element to protect the system from a short from the device you are plugging in, it does not protect the system from a static discharge to your system.
Sadly, you will likely need a new logic board here.
You may also want to make sure you have a good surge suppressor outlet strip that all of the devices are plugged into and check your outlets wiring. You can get a cheap outlet checker at the hardware store to make sure the outlet is wired correctly. You'll need to hire a good electrician to check the houses grounding services and you might also want him to put in a whole house surge suppressor as well which helps when lighting hits nearby.
Lastly, get a spray bottle with some cheap dish soap 1 to 20 mix with water to spray the carpet and cloth seat covers to lessen the static charge you have so when you touch things you don't zap them.
Score 2
Add a comment
Add your answer
darker will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 566
