Repair guides and support for the 2nd-generation Renault Mégane, also known as the Renault Mégane II.
30 Questions View all
la mégane II 2005 ne repond pas electriquement
Score 4
Add a comment
Most Helpful Answer
I assume you are talking about the pas = electronic power steering , it has to go onto a Renault diagnostic unit ,Renault will charge you appx €1500/2000 for another unit ,but there are companies out there that are a lot cheaper !
Score 1
Add a comment
Ma megane coupe le moteur aprer chaque demarage et elle ecri sur hordinateur panne de l'injiction
Score 1
Add a comment
google ECU TESTING or go onto youtube and check out faults with your model !
Solder used in the EEC has a high alloy content [ they dont like lead ] so the joints suffer from poor conductivity its a common problem !
Add a comment
Add your answer
hakim rr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 3,661
