MacBook won't power on, what can I test?
Hi,
My Macbook suddenly powered off (split sececond to blackscreen, like a power outage).
And since wont turn on again.
My Macsafe connector shines dim green, (not sure if this was the case before).
My battery indicator does not work.
What are the test i can run to check what exactly the problem is ?
Can i test if the logicboard is 100% fuctional ? how ?
Thank you.
Regards
7 Comments
Did you get your system wet at some point? It sounds like you have a power issue inside. But you'll need to open the system up to figure this out.
by Dan
No absolutely not.
It was running on heavy load when it happend.
I checked my cable and its 100% good, cause i checked it with a 100% working mac and the led shined bright green.
On this macbook its verry dim green.
I have no problem opening the macbook up myself, what can do/check to understand what the source of the problem is ?
by Ed DeHaas
Can you give us the last four digits of your serial number so we can correctly identify your system.
by Dan
5AGX
Thanks!
by Ed DeHaas
MacBook Pro 15" i5 2.4 GHz (Mid 2010)
by Dan
Show 2 more comments
