SONOS PLAY 5 is the original, bigger room, bigger sound, all-in-one Sonos music player.
36 Questions View all
Question Closed
Can't play purchased Audible audiobook on Sonos
I have a lot of audiobooks purchased from Audible.com. However, I found I could't play these aa/aax files on my sonos very well. I have asked the support man, and was told that the Audible files were DRM protected. How can I remove the DRM and make these audiobooks playable on my sonos? Is there anyone can help me?
Score 2
2 Comments:
Lost ability about december 2015 super frustrating. fight betweem amazon (who bought audible a while back) and sonos. Amazon wants to control the market and push people towards Alexa system!!! dont upgrade and you will be golden. Upgrade and you get DOWNGRADED
by
Hello, I have met the similar issue ever, thanks to AudFree Audible Audiobook Converter, it enable me to convert Audible AA/AAX files to MP3 so that I can transfer them to my iPod. Hope it's helpful for you. https://www.audfree.com/drm-audio-conver...
by
Add a comment
Hi, you can try a 3rd party application called TunesKit Audiobook Converter. It can bypass the audible DRM with fast speed and convert Audible aa/aax files to common MP3 format. Then it's easy to play the Audible audiobook on your Sonos.
http://www.tuneskit.com/audiobook-tips/c...
Score -1
Add a comment
I just met the same problem with you. But luckily, I found a solution on Google to remove the DRM from Audible audiobooks by converting the AA files to DRM-free MP3. And then you can transfer your Audible audiobooks to Sonos and enjoy on it.
Score -1
Add a comment
Audible audiobook is protected with DRM encryption is AA/AAX/M4B/M4P format,if you want to play purchased Audible audiobook on Sonos, MP3, iPod nano, Android devices or other non-Apple devices,you must to convert purchased Audiobooks to MP3.
What you need is an Apple Music Converter,which also is an AudioBook Converter for Mac is designed to remove DRM from iTunes Audiobooks and convert them to popular formats such as MP3, AAC, AC3, AIFF, AU, FLAC, M4A, M4R, and MKA, and then, users can play their purchased Audiobooks on various devices. Also you can choose to save ID tags and metadata information to the output MP3 and M4A files or keep Chapter information in the converted M4A files.
Step 1: Import audiobook to the software and Select Audiobooks
Step 2: Determine output formats - MP3
Step 3: Select Output Folder (optional)
Step 4:Customize output filename (optional)
Step 5: Convert purchased iTunes Audiobooks to MP3
Read More: How to Convert Audible AA/AAX Audiobooks to MP3
Score -1
Add a comment
You can try TuneFab Apple Music Converter. It is not only the converter for DRM-ed Apple Music and iTunes audiobooks, but also the audiobook DRM removal for Audible audiobooks. That means you can use it to convert AA to MP3 easily.
Score -1
1 Comment:
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,512
