The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
295 Questions View all
Knob for settings won't turn off water
This is an older model and when I turned it on for the first time it flooded the utility room. I turned off the water and checked for any leakage but there was none. I reset and ran a full cycle with no problem. However, when I waited about 15 minutes after the cycle completed, the water started to flow into the machine and the knob wouldn't shut it off no matter what setting I had it on. Do I need a new knob for this? Thank you
Comments:
Does it fill with water even when it is turned off?
by
Yep, it looks like from what I read in the online manual for this Kenmoore model that I need Kenmoore appliance repairman here, but thanks for the info. I need a new pressure switch.
by
Add a comment
1 Answer
Chosen Solution
Washwoman, remove your top console and take a look on the left side to check and see if and see if the hose is off the switch. If it i, reconnect it. Check to see if it still overflows. If it does, you most likely will need a need a pressure switch. If you give us your model number, we might be able to get more information on the actual job.
Score 1
Add a comment
Add your answer
Washwoman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 72
