Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
What could be causing my screen to go black at certain angles?
Macbook Pro 13" Mid 2012 A1278
I've done some poking around forums and haven't found an answer that fits my exact situation yet. My MacBook Pro's screen goes black unless I tilt it to certain angles.
I have seen some people talking about whether you can see the screen faintly if you shine a flashlight on it. I tried that, but I could not see the screen shining a flashlight on it.
It is also interesting that this issue started over a week ago, and it would only work if the computer was at about 45-55 degree angle which is very hard to work at. However, when I was looking at it again today, now I can extend it almost to 90 degrees which his good because it's easier to work from but the screen still goes black if I extended to 90 degrees or beyond.
I hooked up my husband's external/dual monitor to it and that works fine and does not go out when I tilt the screen, so I think that is a good sign?
It is worth noting that I ran the Apple Hardware Test but no errors were found. Finally, it may also be worth noting that I just recently put in a new hard drive (well technically I put in a new one, then when the old one got fixed, I put the old one back in). I am not sure if it could be something with that. Should I check to make sure there aren't any lose screws or anything?
One other thing that is happening is that when I try to watch YouTube videos, it says my flash is outdated which I have never seen before. That may be an unrelated thing, though.
Any help would be so greatly appreciated. Thank you so much!!!
Ruth
1 Comment
YouTube uses Adobe Flash. You should go to their web site and download the newest version for your system.
by
Add a comment
1 Answer
Chosen Solution
You may want to review this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Display Replacement. In this case follow the steps down to Step 13 making sure the display data cable is not pinched and also make sure it is fully seated.
It sounds like the cable is rubbing somewhere along the hinge.
Score 1
Add a comment
Add your answer
Ruth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 6,133
