iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
376 Questions View all
My 1tb hard rive in my 27" late 2009 iMac makes sounds and doesn't run
It makes a beeping sound when it gets turned on. Also it doesn't recognize that there even is a hardrive. The computer doesn't even load up anything.
Link To See What It Sounds Like: https://youtu.be/tRDi5jNTjds
Comments:
Can you give us the last four digits of your serial number. You'll find it on the bottom of the systems foot. That way we can guide you the reset of the way and aim you to the best drive for your system.
by
the recall on the 1TB Seagate ended 4/2013: http://9to5mac.com/2012/10/19/apple-send...
by
Add a comment
1 Answer
Chosen Solution
Ah... The ticking Time Bomb problem! Sadly, your drive has bit the dust here, its time for a new drive.
Score 2
Comments:
This may be one with the proprietary sensor cable, so check before just ordering any drive.
by
Thanks Mayer! Forgot to point that out - So true! If you do want to switch to a different drive make you can! But, you will need to swap out the sensor cable to the correct one for the drive you are putting in.
by
Add a comment
Add your answer
alexab9909 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 116
