TV will not power up, red light flashes 10 times.
I have a Panasonic THP46U20A TV. It exhibits 10 Flashes of Death. I tried the basics unplug replug it in press the power button for 10 secs, remove the back & remove all trace of dust with compressed air, unplug & replug all removable plugs on circuit boards, (strangely I didn't see any fans) & then I re-tested it no joy, so the problem has to be deeper. I was wondering if old Turkey may have a manual or diagrams for this one. It was built July 2010, I understand there is 3 main fail points on the P board. A thermal fuse which is hidden in the transformer that can be replaced by bypassing the original (without removing the original) & mounting it externally on the top side of the transformer). The thermal fuse is a cheap item I can buy from JayCar its knowing where to attach the bypass leads on the circuit board. The next most common fail I believe is the ceramic resistor. (I would just do both items together & then try it I think, can any one help with advice, manuals, diagrams etc Kind Regards Phillip
