The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
594 Questions View all
Is it possible to change flash chip on motherboard...
Comments:
Exactly what chip do you want to change and why?
by
The flash chip,the phone do not starts and the tecnician sad that it needs to change flash chip.
by
the only "flash chip" is the nand memory. Is that what the technician refers to? what have you tried so far? What have you checked? How was determination made that it is the "flash chip" that needs to be replaced?
by
I do not know how he checked,but that is what he sad, to change the nand flash.
by
Thanks,for so detailed and short answer.So if I understand well with this kind of problem it will be better to replace the complete motherboard.
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
maximdu, if you need to replace the NAND flash memory, you need to realize that the Samsung galaxy S3 uses a Samsung KMVTU000LM IC. The IC itself is widely available for ~$15.00USD, but the package of the IC is a FBGA and as such will require a reball. Unless you have access to the proper tools and the proper solder balls and stencils, this will most likely coast you more than a new phone.
Score 1
Add a comment
Add your answer
maximdu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 527
