The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3316 Questions View all
Blue screen crash after charge port replacement?
Ok so this has happened twice now with two different iPhone 5S. The first time sorted itself out after a restore of the phone through iTunes but this time I've tried almost everything I can think of but the phone just keeps crashing with a blue screen then re-booting. It happens every 5-10 minutes.
It happened after I replaced the charge port. I know this can happen when you put the wrong screws into the plate that hold the lcd/digitizer flex down but I haven't been near that plate. Didn't even remove the screws for the screen. All I did was a regular charge port replacement, all of the correct screws were put back in there correct places. The phone charges, syncs to iTunes and functions correctly in all other ways. I just can't seem to get my head around why this is happening. It seems to be a common problem but only when mixing up the screws for the screen. If this has happened to any of you guys please let me know. Any information will help.
Things I tried:
-Brand new battery replacement
-Tried another charge port
-Updated the iPhone
-Restored the iPhone
Thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
grab a needle and poke on the caps near the batteryconnector especially FL11, im having the exact same issue as you and the screen never came off, but the FL11 cap has come loose.
Score 1
Comments:
FL11 is not a cap, it is a filter (inductor)
by
hopefully he knew what i meant anyway
by
Add a comment
Most Helpful Answer
So you changed the port and didn't remove screen?
That must have been tricky and must admit that's very bad practice..
You must be damaging something when your doing your repairs or else this issue wouldn't happen
Do you use anti static mat ?
Was battery disconnected before the repair?
Score 1
Comments:
I dont find it tricky at all and don't see how this is bad practice? I use an iHold to properly hold the screen up. Why take it out when I don't have to? Yes the battery was the first thing I disconnected and yes I use an anti static mat.
by
Well then your damaging something on the board when your repairing
by
Yeah well that's what I'm trying to figure out. If anyone has done this before that may know what I might have damaged. Everything on the board looks good and I'm usually very careful using soft plastic spudgers to remove the battery and other flex cables.
by
Add a comment
That means your iPhone 5s screen is damaged. You can ask your local repair store for help or try to replace it by yourself.
Score -1
Add a comment
Add your answer
craigad24 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 459
