WiFi/Bluetooth antenna problem after thermal paste replacement
I recently replaced the thermal paste on my ps4 the console works fine but my controllers seem to loose signal and not respond as should. I took the playstation back apart and realised that the antenna cable does not touch the second solder point on the metal bracket at the front off the console. Could that be the problem and is it as simple as re soldering the cable onto the second point.
Thanks Nathan
